LML ECM just died?
Old 05-21-2018, 10:23 AM
Burnett03's Avatar
Default LML ECM just died?
Hey guys. I flashed my brothers truck about two months ago with a tune from Motor Ops. Truck has been running good until Friday night. He was driving pulling a trailer and the truck just died on him. He was able to coast to the side of the road. We checked all the ecm fuses and they all seem good. The dash is currently saying "Service trailer brakes, service stabilitrak, parking sensors blocked". I can no longer communicate with the ecm. When i use EFI live i can see the A50 TCM but the ecm box comes up blank like it isn't there. Seems odd that the truck just shut off while driving and now won't restart. Tried jumping it incase it was the batteries with no luck. The truck wont even try to crank which i believe is do to the ecm being dead. Any ideas?
Old 05-21-2018, 11:04 AM
Custm2500's Rude Friend
1FastBrick's Avatar
I have heard of them dying but not sure what causes it.
Might have better luck poking around the diesel sites.
Old 05-21-2018, 01:02 PM
Burnett03's Avatar
Thank you, i've cross posted to other places also.
Old 05-23-2018, 07:57 AM
MikeGyver's Avatar
Fuses "seem" good?
Old 05-23-2018, 12:02 PM
Burnett03's Avatar
Originally Posted by MikeGyver
Fuses "seem" good?
They all test out as good with my ohm meter.
Old 05-23-2018, 03:18 PM
turboal1's Avatar
Default Ecm
Did you plug a scan tool into the OBD port ?
to see if any codes show up ?
Old 05-23-2018, 04:56 PM
Burnett03's Avatar
I was unable to pull any codes with EFI live through the ecm. No communication. A guy at work was able to pull some off a system scan through the tcm/bcm. But it only showed low battery voltage (which was when we removed the cables off the batteries) We've installed two new batteries and got a used ecm that I'm going to try.
thunder550
11-12-2015 06:34 PM
joeyc125
04-05-2014 04:00 PM
thunder550
02-22-2014 04:56 PM
GHBB3
02-18-2014 06:14 AM
The1N_only
03-12-2012 01:51 PM
Quick Reply: LML ECM just died?
