lc-1 to pcm?
Old Nov 18, 2013 | 06:21 PM
hodge9386's Avatar
12 Second Club
Default lc-1 to pcm?
Is there a way to hook a wideband to the pcm and create a custom pid in HPT to read afr's in a 02 silverado pcm? I know it can be done on F-bodys because i did it on my firebird and it worked great. On f-bodys you just put the ac pressure switch on a on-off-on switch and when i want to tune i switch it to read the wideband signal through the pcm and have a custom pid set up to use the 5v ref to read my afr's. I know that is comfusing so here is the link to set it up (https://ls1tech.com/forums/pcm-diagn...eio-print.html). is there any way to do the same thing to a 02 silverado pcm? i guess i just need to know what sensor used a 5v ref and i can set up the pid.
Old Nov 18, 2013 | 06:28 PM
03sierraslt's Avatar
Do you have HPT MPVI Std or PRO?
Old Nov 18, 2013 | 06:30 PM
hodge9386's Avatar
12 Second Club
its standard. if i had pro i could just plug the wideband wire in to the eio.
Old Nov 18, 2013 | 06:38 PM
hodge9386's Avatar
12 Second Club
i basically just need to know if there is a 5v referenced sensor that isnt a major sensor the pcm uses to make the truck run correctly like a ac pressure or something like that i can tap in to. i can prolly fiddle around use the pid for my firebird to make a pid for the truck using the correct sensor.
Old Nov 18, 2013 | 06:41 PM
Vortec350ss's Avatar
There are ways to do it like you said wiring in one of the signal wires to the PCM... I didnt want to go through that hassle or mess with PCM wiring any more than I had to. I upgraded to pro.
Old Nov 18, 2013 | 06:47 PM
hodge9386's Avatar
12 Second Club
yea i dont really want to spend another $250 to send mine in to get upgraded. its not really that hard and once its set up its just a flip of a switch, its kinda nice actually.
Old Nov 24, 2013 | 11:51 PM
Steve-O-08's Avatar
You could use the egr wiring. You can disable the egr in the tune and use the wiring harness for it. Basically the same way you used the a/c pressure switch with a custom pid.
Wrecker 426
Sep 30, 2015 09:39 PM
Velocity1
Sep 22, 2015 01:32 PM
kalikid06
Sep 20, 2015 07:46 PM
muncie21
Sep 7, 2015 09:55 PM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
