Larger Injectors Tuning
Old Nov 21, 2011 | 08:37 PM
Last Call's Avatar
TOTM: January 2007
Originally Posted by 364HC
i have the injector value tables on both hptuners/efi live
Can you please send them to me in efilive tune format?
My email is j_port21@yahoo.com
Thanks!!!!
Old Nov 21, 2011 | 08:39 PM
Last Call's Avatar
TOTM: January 2007
Originally Posted by swift700
I would return those injectors and get some Siemens/Deka injectors. There is no proper data available for those anywhere. Ask me how I know. You can get them to run but they'll never be right without the proper data, and unfortunately it's non-existant. The guy that builds and sells them knows this but won't admit that anything more is required than what comes on that little card.
Definitely not good news!!! I will see how it goes once I get the data and go from there.
Old Nov 21, 2011 | 10:13 PM
swift700's Avatar
I sent you my file. The only good thing about these injectors if that they are a direct swap for the factory ones. If only there was some good data...
Old Nov 21, 2011 | 11:03 PM
Last Call's Avatar
TOTM: January 2007
I received your email, except I have efilive. I am going to ask a friend to see if he can open and take screen shots of the tables.
Thanks man, appreciate it.
Old Nov 21, 2011 | 11:07 PM
TurboJohn6's Avatar
I have these same injectors and I was under the impression that they worked great. I have not installed them yet, but I am planing on it. Did anyone talk to Justin @ Blackbear about tuning with these injectors? I believe he is familar with them. This is the first negative feedback that I have heard off on these.
Old Nov 22, 2011 | 04:17 PM
Beatdown Z's Avatar
Laid Back
Can one of you guys send me the data for these injectors at justinfbomb@aol.com? I'm going to be starting my tune in about a month(hptuners) and having some decent data would be a huge help.
Old Nov 22, 2011 | 05:39 PM
swift700's Avatar
I had Nelson try and tune these injectors but even he had trouble with certain parts of the tune, namely the cold idle and acceleration. I've since tweaked them to run pretty good.
TurboJohn6, I will get you a copy of my tune when I get back in a couple days.
Old Nov 22, 2011 | 09:44 PM
KLUG'S SS's Avatar
FormerVendor
Originally Posted by smokeshow
You'll need a much wider range of IFR data than you have listed to fill the table. You'll need minimum pulse width, but I don't see a lot of variation from 0.8ms with 60lb injectors, so you could probably use that value... Also need short pulse adder information, and definitely a lot more information on latency. Injector response time is also affected by manifold pressure so you are going to need a whole table for injector offset on a graph with respect to voltage and vacuum.
So basically, you need a lot more information What injectors are they?
Old Nov 22, 2011 | 09:59 PM
KLUG'S SS's Avatar
FormerVendor
And another to you also.
As I always come on here on preach just getting the IFR entered in correctly in the tune is only a small part of the equation when it comes to tuning in different injectors. The reason I probably always sound like a broken record about is because it is very important to get the other "correct" data changed to match the characterization of the injector being used.
Yes these injectors are of course a very inviting and logical choice being how nice it is that they are plug and play but with this also comes with a lot of headaches getting them tuned in right. Can it be done? Sure. Has it been done? Sure guys are using these and have gotten them to work but for a number of the self tuners out there who may be a little less experienced for example may end up down a rough road of tuning a larger injector without having the right data.
Old Nov 23, 2011 | 09:04 AM
TurboJohn6's Avatar
I would appreciate it....Thanks!
