knock retard why??
Old Oct 23, 2005 | 08:46 PM
TURBHOE's Avatar
Default knock retard why??
ok i've been doing some tuning and playing around and this whole time i thought i had a great tune well come to find out a person that was helping me tune disabled my knock sensors. i found out becouse i got a low voltage knock sensor code a couple of times and i was trying to figure out what he did to fix the weird knock i was getting and i found all the tables zeroed out. so i was doing so ve tuning in sd and it seemed to be running really well then i connected my maf and now i get crazy kr and it feels like a turd of the line where it didn't before and just now i went out side to check my cig lighter fuse and it was blown and i fixed it and connected hpt to the truck to see if that was why i couldn't connect and it was but as i was sitting there i reved it up a couple of time and got anywhere from 3-5* of kr. and the max timming was 25* it usually just comes where i'm going up a steep incline at low speed high gear and the tc has to unlock or is not locked.
Old Oct 23, 2005 | 09:06 PM
02sierraz71_5.3's Avatar
set kr tables back to stock then research which tables you need to adjust
Old Oct 23, 2005 | 09:24 PM
TURBHOE's Avatar
just did that i think i got them back to stock i'm not sure. i don't really have a stock tune. i gotta do some more data loging.
Old Oct 24, 2005 | 02:06 PM
TURBHOE's Avatar
can a loud exhaust cause knock retard. i have no muffler i took it of and i keep getting knock retard in the same spot no matter how much timming i take away. so could it be the exhaust. it always at the same time on small inclines in overdrive with tcc unlocked and giving it about half throttle or so.
Old Oct 24, 2005 | 04:51 PM
yes I have the same problem so do others. Alot of the kr tables for trucks are overly sensetive go to horists website download a stock tune and go from there. If you run 93 all the time cut the max kr vs rpm in half so instead of -10 you should have -5. Under the calibration tab adjust the tip in tps and rpm tables especially down low where the tcc is locked also rpm vs cyl can be tweaked that should help out alot but now you must run 93 all the time. Raise burst kr
Old Oct 24, 2005 | 07:34 PM
TURBHOE's Avatar
thanks for the help i'll try that. how can i post up or give someone my data logs to look at?
Old Oct 24, 2005 | 08:24 PM
send them as an attachment via email
Old Oct 24, 2005 | 09:00 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Damn 02sierraz71_5.3 you seem to realy know your **** on using HPT.
Dont take this as a post ***** comment I am simply giving you a comment I am trying to read up using HPT cause I plan on buying it soon and you really seem to know your stuff.
Old Oct 25, 2005 | 07:07 AM
TURBHOE's Avatar
would you like to see my datalogs you can see where the kr is almost same place same time everytime. maybe you can clearafy some of this for me.
Old Oct 25, 2005 | 09:05 AM
sure, Ill can send you a stock tune when you send me yours
pm sent
Pimpinpete
43
Dec 22, 2017 08:13 AM
dantheman1540
14
Sep 28, 2015 09:22 PM
trevorh1
Sep 27, 2015 08:47 PM
ZxHybrid
Sep 18, 2015 04:44 PM
Pimpinpete
Sep 8, 2015 07:39 PM
