Just wondering....how accurate?
Old Mar 12, 2008 | 10:00 AM
  #21
cmitchell17's Avatar
My 5.3 usally only shows a max of about 305ft.lbs. And this usally comes up below 3000rpms where MAP still matches BARO.
Ive scanned another stock 5.3 and it shows about the same thing.
Ive scanned a stock LQ9 that showed right at 360 where it was rated.
Old Mar 12, 2008 | 10:02 AM
  #22
trever1t's Avatar
2nd fastest 5.3 ECSB
mine showed 505 pretty consistant on a wot run without nitrous. I assume this is calculated crank tq?
Old Mar 12, 2008 | 10:26 AM
  #23
BlackGMC's Avatar
Resident Retard
I believe there is a TM setting/control that controls how much it will make, mainly B1901
Check out the following tables....
{B1901} Max Allowed Engine Torque
{B6601} Axle Torque Limiting
{B6615} Max Torque, Front Axle
{B6616} Max Torque, Rear Axle
{B6617} Max Torque, Front Prop Shaft
{B6618} Max Torque, Rear Prop Shaft
{B6619} Max Torque, Trans Input Shaft
{B6620} Max Torque, Trans Output Shaft
Old Mar 12, 2008 | 04:00 PM
  #24
03sierraslt's Avatar
I have seen mine hit 6xx something but I always thought this was a bogus reading that the computer used not something that was actual or close to it for that matter.
Old Mar 13, 2008 | 09:58 AM
  #25
Yeah thanks Black GMC that reminds me that I need to check it.
Im pretty sure that I set it to max but ill check it again.
Maybe theres a hidden table in EFI live that I can't see thats making it do this. But I have seen as high as about 316ft.lbs.
JordanH
Oct 3, 2015 03:59 PM
CHarris
Jul 11, 2005 12:49 AM
NateZ
Dec 30, 2004 06:26 PM
