Just got back from the track?
There are a few places you can pull timing from. The boost timing table in the custom OS stuff, IAT timing table under spark or high/low octane timing. I would pull the timing from the high octane in this case because the KR doesn't come back in the log, and you only want to pull in one specific area. If you pull any timing from the IAT or boost timing tables they will affect the timing all the time, not just in this airflow/RPM range right after the shift.
Did you hear any knock during the run? Do you have a wideband gauge, I'm wondering if there is a lean spike anywhere.
Congrats on the great new times. Your speed is good for lower 12's/hi 11's! Yank recommends NOT locking the converter wot...I just talked with Dave@Yank early this week about it.
I can't see your tune or logs (hpt guy here) but the KR you see could be from the added load from the TCC apply?
Anyway, great runs!
Anyway, great runs!
Download the software from here http://www.efilive.com/download.aspx and install it. It's the most current full version that will function in demo mode (won't let you save changes) until a registration key is entered
