Issues with 2001 5.3 Silverado
#21
What kind of spark plugs Did you use???
Can you try this for me??? hook up fuel gauge, turn on engine, record data fuel trims and fuel pressure, then pull of the vacum line to the Fuel pressure regulator and record the Pressure and data???
The pressure should go up 10PSI with the regulator un-pluged. The data will will determine if you have a possible intake leak.
#22
So, I hooked up the pressure tester, and at an idle it was reading 50 PSI, and the short term trims on both side were even, and right around 0.00 to -1.5. I thought that to be normal. Pulled the vacuum line, and the pressure jumped to 59 PSI, and the short term trims didn't move much, just to the positive side of 0.00 to around +1.50
Seem pretty normal eh? I was going to put the fuel filter on this afternoon.
#23
OK, changed the fuel filter for good measure, and no change. Still getting misfires on all cylinders, but, it seems that most are coming from cyclinder 1. Also, another P0300 code. Looking for ideas now guys.
#24
I restored the factory PCM programming, and loaded the canned 87 octane tune. Drove it around for a bit. What I noticed is, the throttle response and power was noticeably better. (imagine that) what did not go away, however, was the misfires. The tune might suck, but that is doesn't seem to be causing the misfires. I also noticed that, and reconfirmed, that most of the misfires are happening at idle, or at light throttle. During excelleration, i'm not seeing any misfires on any cylinders.
#26
I left the canned 87 octane tune in, and the truck drives great. I'm still showing misfires on the predator, but i'm not feeling them during driving. Filled up with some fresh fuel. What gives?
#27
Just a quick update, but I was going down the road today, at cruise speed, and lightly pressed the throttle to gently increase speed (not to exit overdrive), and it started stumbling. Also, let the truck warm up a bit, then sprayed around the manifold and such with carb cleaner to see if the idle jumped, notta. I can't believe you guys are stumped. Toss me a bone or something.
#29
#30
Sorry as mentioned this is free help and it's the first time I have had a chance to check in on this.
Fuel trims seem ok but Intake gaskets is a possibility.
How old are the plugs??? How long after they were changed did this issue start???
You said you checked the the plug wires??? How did you check them and what brand are they???
Are you haveing any over heating issues or loss of coolant???
How about smoking or loss of oil???
Aside from that you may need an in depth diagnostic check.
