injectors 3-4-5-6-7 not working?
well after my problem with the spark plugs
Originally Posted by sand man
(Post 4880593)
http://i933.photobucket.com/albums/a...0302-00548.jpg
this is what happend, the head of these spark plugs fell in the cyl # 3 and 5 ill remove the head tomorow. i reinstalled my old iridums what is the cause? are the copper cores not compatable with my setup? in cyl number 3-5 the intake valves were bent so i changed them with new ones and check the valve seating on the head and every thing was put back together like new , fired up the truck and it shackes like hell! checked every thing i can think of untill i reached the injectors 3-4-5-6-7 and tested all of them , inj# 7 actually works at the start ups for 3 to 5 pulses then it stops. agine i checked every thing tested the injector wires there was no ground ( negative) that reaches the injectors . so i unpluged the ECM and checked if the wires would transfer power , and they did. so the only reasonable thing i can think of is the ECM is bad, how, and why, i dont know! any one has any input on this issue? the truck has been setting for a mounth now and im sick of driving the grand marquis:( FYI: there are no cods shown about this problem , just a code about the MAP sensor. |
Bad drivers aren't uncommon for PCMs.
Do a ground check on the wire from the injector to the PCM to see if, indeed, the PCM does not switch ground properly. You could accomplish this with a duty ratio or Hz capable multimeter, but a labscope would get you much higher accuracy. |
