Idle Tuning
Old Sep 30, 2010 | 04:58 PM
  #21
GMCtrk's Avatar
Originally Posted by blsnelling
The new tune is in. I haven't driven it yet, but it started right up and idled much better than it has been. I turned the fuel pressure back down to 59 PSI with the vacuum hose off. Is that correct, or should it be 58 PSI?
I changed the Desired Idle Speeds to 600, but it's still idling at 700. Is there another table that affects the idle speed? I did make sure that the idle stop screw on the t-body wasn't holding it open. The bleed screw is closed as well.
Email me the most updated tune again.
Like I mentioned above, even with the minor fueling and spark adjustments I made, that 6.0 is going to idle perfectly with that mild cam. The PCM will make it's own adjustments as well which will help things.
Old Sep 30, 2010 | 07:59 PM
  #22
BlackGMC's Avatar
Resident Retard
here is a nice read
http://forum.efilive.com/showthread....ips-amp-Tricks
noproblems209
Aug 10, 2015 06:57 PM
Suburbazine
Aug 9, 2015 01:17 AM
fillpot
Jul 26, 2015 07:21 PM
GMCtrk
Jul 17, 2015 06:39 PM
GreyChevy
Jul 7, 2015 08:57 PM
