Idle in EFI COS3
Anybody have some advice in tuning the idle up in COS3. I have it set to OL and Disabled STFT Idle Enable: to run fueling off the B3647 and B3649 exclusively. It seems to want to run a little bit ruff and will stall from time to time. It never did that with the MAF enabled until I tried to tune the Idle trims using RAFIG. I think I returned it to stock settings but it still stalls from time to time.
Maybe i'm not understanding.. Is it idling too high / too low?
I just put COS3 in mine and all the idle settings stayed the same.. i just adjust the Idle AFR to make it lope more or less
I disabled the STFT Idle because it said to if you want to use the B3647 and b3649 commanded fuel vs rpm fuelling exclusively. I figured I would do that until I have time to do an auto ve.
The idle speed is the same as before but it seems to stumble a bit and stalls every once in a while once it is up to operating temperature.
Made a typo before. The tune is in OL not CL and LTFT is disabled and Closed Loop Temp Enabled is set to Max.
I have done a little work on the idle following the tutorial on EFILive. It still wanted to stall once in a while especially when coming to a stop after driving for a while and especially when putting it into reverse. Not sure if I might still be able to fine tune it a little, but I upped the idle speed from 575 rpm to 675 rpm once the truck is warmed up and it has pretty much cured the problem.
