I just FREAKING love Idle tuning.....
Old Jan 12, 2009 | 08:36 PM
  #21
BlackGMC's Avatar
Resident Retard
When you start yours up does it rev up a little then just fall on it's face?
Old Jan 12, 2009 | 08:47 PM
  #22
Whippled 496's Avatar
No, it never surges...it just barely fires up and just lopes at about 200-300 rpm. Sometimes it will catch up with its self if i let it go, but it takes a good 10 seconds to do. However, if it does it, and i immediately shut down, then immediately fire up again.....it starts fine. Weird. Basically this is how it works. Truck has been parked overnight in the garage. I get in and turn the key. It barely fires up so i instantly shut off, then instantly turn the key again and it fires up fine. If i dont shut down, it will lope around 200-300 rpm untill it catches up and starts to idle fine. It does this on maybe 25% of cold start ups. Never when its either warm outside or the engine is already warm. I was leaning toward a fuel pump issue originally, but that isnt it. I thought maybe it had to do with the questionable data in the injector tables that i used for the siemen 60lb injectors. Then i just gave up trying to figure it out because ofthe simple solution of just shutting off immediately and firing it back up. I would love to figure out what it is though. I thought Jessie may have some ideas. I didnt mean to F your thread up Corey....sorry.
Old Jan 12, 2009 | 08:51 PM
  #23
BlackGMC's Avatar
Resident Retard
Does your tune have B4343? if so try adding a little bit start with .5-1 gram in the colder temp areas, it may take more, but start out low and work your way up... if you get a big rev when you start it, then you have added tooo much...
Old Jan 12, 2009 | 08:57 PM
  #24
Yeah, i have B4343 I Will give it a shot. thanks Corey.
Did the RAFPN/RAFGR thing make a differnce when you did it?
Old Jan 12, 2009 | 08:58 PM
  #25
BlackGMC's Avatar
Resident Retard
Yep, it did, but coupled with my smaller diameter/light converter and -1* overlap cam it took alot more work, let me know how that goes, there are a couple other things you can try next.
Old Jan 12, 2009 | 09:01 PM
  #26
Probably wont be driving it again until the weekend, but i will give it a shot and see what happens....thanks man.
Old Jan 12, 2009 | 09:02 PM
  #27
BlackGMC's Avatar
Resident Retard
Pimpinpete
43
Dec 22, 2017 08:13 AM
bearden86
26
Nov 15, 2015 03:58 PM
BlownHD
Oct 3, 2015 12:24 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
