HUGE gains with MAF removed completely...
Old Jul 22, 2006 | 04:11 AM
  #21
Wilde Racing's Avatar
How do I change this text
Originally Posted by Yelo
Nothing changed except my trims which went positive due to the increased airflow....
I knew there had to be a catch somewhere, I would have to re tune what the this is bull
I guess I'm going to be ordering my air intake sensor monday.
1slowsilverado;
I am running my IAT sensor in where my EGR used to be in the Intake with good results for hot restarts, but its still work in progress.
How bad is the hot restarts? and how long until it cools down enough to give a good reading?
Old Jul 22, 2006 | 07:10 AM
  #22
Yelo: Good find, looks like I might just be on my way of ditching the MAF or sell the one that is on there know and gut the stock unit.
Old Jul 22, 2006 | 09:44 AM
  #23
Kano's Avatar
OK....here's the answers
dewmanshu: Tell me how to set the histograms in HPT to read a table that references a sensor that isn't there anymore and I'll gladly fix it (I'm being serious here, NOT sarcastic)....HOW is g/cyl derived if not from the MAF ??
EVERY histogram in HPTuners that references g/cyl will only show one line of data instead of filling in the whole table...if someone can tell me how to fix it I'll galdly do so
what g/cyl is it showing?
how does this correlate with your timing tables
ex. if youre only reading .08 g/cyl how does your timing look at lets say 4000 RPM?
then compare it to an old log with the maf in place at wot g/cyl
4000RPM
seems to me like there would be a huge jump in timing unless you adjusted your timing tables to compensate for only running one line
and possibly even unsafe with the higher values in the lower load areas
and the pcm thinking its at low load all the time
I think youre on to something good here
but I think its more to it in your situation than just freeing up the air a bit
Old Jul 22, 2006 | 12:34 PM
  #24
dc_justin's Avatar
Hello Dave
The PCM would not think it is in low load all the time. The MAF is only one part of the equation for calculating airmass. With it out of place, the VE table is used entirely for determining what g/cyl is occuring.
Old Jul 22, 2006 | 12:48 PM
  #25
Yelo's Avatar
Kano is right....if you set the MAF fail to 0hz the PCM will ignore it and go straight to using the VE table to calculate fuel.
Old Jul 22, 2006 | 01:39 PM
  #26
dc_justin's Avatar
Hello Dave
No, he's postulating that since since your Histogram is showing all spark values in one row, that your PCM is running off of the .08 g/cyl column (row in HPT case) in the spark table and could be dangerous, as it is running low-load timing in high-load operation.
What I stated (paraphrased) was that with the MAF in place, the PCM uses a blend of both the MAF and VE table lookup value to determine what the dynamic cylinder airflow value is, which is what all spark table lookup is based on. With the MAF out of commission, the VE table is the SOLE source for the PCM to determine what airflow is in the cylinder. Therefore, using some g/cyl calculation derived from the MAF would be completely inaccurate. You need to log the correct PID that would show what the PCM is using for its calculations.
Old Jul 22, 2006 | 02:14 PM
  #27
Yelo's Avatar
OOPS....I meant: dc_justin is right....Sorry guys
Old Jul 22, 2006 | 02:35 PM
  #28
RedHardSupra's Avatar
1. spark table is looked up based on dyncylair, not dynair/maf
2. dynair/maf can be converted to dyncylair, through the means of rpm
3. pcm doesn't care where it gets the airflow readings (ve/sd or maf or mix of them), just uses what it can.
4. dynair is to dyncylair what hp is to tq
5. dyncyl air has lousy resolution, but dynair has a lot of error inherent to the difficulty of measuring airflow. so which one you use is up to you, experiment and see which one yields more consistent results
Old Jul 22, 2006 | 05:21 PM
  #29
Kano's Avatar
OK that makes better sense
Yelo,
are you still runnin the ls1 intake?
Old Jul 22, 2006 | 06:43 PM
  #30
dewmanshu's Avatar
Moderately Differentiated
Okay, so are we are back on track now?
Now the real question, are you feeling better response/power due to the freeing up air restriction OR you have being dynair/maf all along and now it is dyncylair?
BTW, KY BOB, this is exactly why I unplugged it along time ago. To make sure the pcm doesn't use it....AT ALL. I know all about how to zero the mail failure, even zeroing out the table. My IAT is in the Radix Blower.
