HPTuners - What else?
Old Jan 20, 2009 | 10:06 AM
gdev_'s Avatar
Default HPTuners - What else?
Hi all, going to be purchasing the HPtuners VCM Suite Pro version, is there anything else I need? I am planning on hooking up a wideband, do I need to get the plug (MPVI Pro EIO)?
TIA
Old Jan 20, 2009 | 10:26 AM
Wilde Racing's Avatar
How do I change this text
You "CAN" hook up the wideband without the "PRO" version by going through the EGR system, but It is WAY easier just to buy the pro....
Old Jan 20, 2009 | 11:32 AM
kbracing96's Avatar
If you get EFILive V2 cable, and a LC-1 WB, you can plug the serial out put form the LC-1 directly in to the V2 controller and log serial WB data instead of just analog. The V2 will also display the current WB reading right on the display screen. It's a very nice setup. I can hook you up with a package deal if you like.
Old Jan 20, 2009 | 11:50 AM
alanderson1978's Avatar
The MPVI Pro comes with the plug for EIO.
Which Wideband are you getting?
Old Jan 20, 2009 | 02:18 PM
gdev_'s Avatar
It has been suggested to stay away from the Innovate stuff, so far looking like the NGK AFX.
Apparently there are (were?) issues with the LC-1 and LM-1s? Do you have any other suggestions recommendations?
Edit: Thanks for the offer KB, already ordered the Pro via HPtuners.
Old Jan 20, 2009 | 03:21 PM
KySilverado's Avatar
I and others have had bad luck with the LC1. Don't know that I have ever read anything bad about the LM1.
Old Jan 20, 2009 | 04:32 PM
kbracing96's Avatar
The LC1 probable out sells every other WB by 5 to 1, because it's the cheapest. When there is that many more being sold, your bound to have more fail. BTW, every LC-1 that I know have failed, Innovate has repaired or replaced, even if there where out of warranty.
Old Jan 20, 2009 | 06:17 PM
charcold-bowtie's Avatar
no voltage offsets with serial cable. If i could do it again i would do an lc-1 and plug it into efilive. My analog works ok, but always reads a bit different than my serial gauge that in the truck. Which makes fixing the ve table a pita...
Old Jan 20, 2009 | 10:49 PM
I'm using PLX SM-AFR. It has a box mounted under the hood that is the actual WB controller. You can use their AFR Gauge, or their OLED displays to show the data along with the 0-5v analog signal.
Porscharu914
14
Jan 20, 2016 10:45 AM
Avalanche2002
Nov 30, 2015 07:31 AM
legerwn
56
Nov 15, 2015 10:21 PM
97_ek
Sep 23, 2015 09:16 PM
