HPT scanner configuration Question
for the members using the HPT scanner to log their trucks. what PIDs are you using and not using. this specifically for a boosted application
also correct me if im wrong. your HPT scanner for MAP should read what the sensor is being if its a 1 bar 2 bar or 3 bar correct? so it should read either 0 -105 1 bar 0 - 200 2 bar 0 -315 3 bar |
If your running a 3 bar you have to upgrade to 2.2 version and burn another 2 credits.
Originally Posted by Spoolin
(Post 3998617)
also trying to see what other members are doing for custom scanner on my map under the letters CB A 834 3113 now on back next to nipple AA1-6 now looking at the back of the map with nipple towards the right and the plug on bottom. my A port is solid round [no key slot] my B port has a key slot at 12oclock my C port has a key slot at 3oclock now is this a 3bar or did i get taken |
Does the map bolt directly in your intake?
I have alot of config files set-up, it depends on what I want to tune... If I want to change shift points, I log my trans config and so on... I'll post up a few configs for you if you'd like... |
Originally Posted by Wilde Racing
(Post 3998667)
I have alot of config files set-up, it depends on what I want to tune... If I want to change shift points, I log my trans config and so on... I'll post up a few configs for you if you'd like... yes i would appreciate the scanner config. i made one but not sure if its right or not |
Originally Posted by 7845
(Post 3998848)
no it doesnt bolt right into the intake. it looks like the map that is on a LT1 or older motor. a big box style map. i ended up using a hose to put over the nipple and cut to lenght to get it to slide in the intake port
yes i would appreciate the scanner config. i made one but not sure if its right or not i'll post more once I get home and get the new computer "online" |
alright thanks. yes i read the turtorial from HP to set up the scanner i just hope it works
Did you rescale the MAP sensor in the tune? 1 bar, 2 bar, 3 bar all use the same 0-5v range on the signal, so you have to tell the tune that 0-5v needs to be scaled to the full 315kpa or whatever instead of the stock 105 kpa.
Originally Posted by thunder550
(Post 3998857)
Can someone with HPT verify whether or not the MAP sensor needs to be rescaled with the 2 or 3 bar OS? I'm familiar with EFILive but not HPT.
