HP Tunners & Wide Band Interface
Old Aug 25, 2005 | 05:45 AM
TurboGibbs's Avatar
Default HP Tunners & Wide Band Interface
I have been told that HPT can interface with a Dynojet Wideband Commander but will it interface with an Innovate unit? I understand the Innovate uses the rs232 cable and the Dynojet uses a USB.
Old Aug 25, 2005 | 06:15 AM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Click on the hpt tuners advertisement------------------------->
Go to the ehanced interface part and it should give you a list of all supported products.
Old Aug 26, 2005 | 09:01 AM
12secSS's Avatar
The DynoJet uses a USB to interface with the computer if you want to use their software to log. The Innovate wideband uses a serial adapter to interface with the computer to log data as well. Both can be used as stand alone units to monitor AFR, TPS and RPM. How they interface with HPTuners is both have extrenal outputs for voltage, which HPTuners (if you have the EIO version) will be able to take this signal and record your AFR reading in the scanner. No longer requiring the use of either DynoJet or Innovate's logging software. Clear?
Old Aug 26, 2005 | 09:25 AM
TurboGibbs's Avatar
That's a huge help. Thanks.
thompson
Dec 27, 2017 06:48 AM
BROKE-aSS-BLAZER
Oct 13, 2017 03:50 PM
Gadgetized
Oct 22, 2015 09:06 AM
03sierraslt
14
Oct 9, 2015 05:53 AM
blown02408
Oct 1, 2015 01:06 AM
