HP Tuners: VCM Suite 2.1.12 now available!
#32
How do I change this text
Originally Posted by Yelo
Real Time Tuning ??...as in tuning on the fly ?? and will this work for the serial interface too ??
#33
Moderately Differentiated
Originally Posted by Wilde Racing
YES! but only for 99-02 ECM I believe. I played around with it sitting in my drive way. it's pretty cool Would be way cool on a dyno
#35
Originally Posted by Zick
You'll have to go back to an older tune that doesn't have the 1/2/3 Bar enhancement done if you already have a 1/2/3 Bar upgrade. Open that up w/ editor and then click on the OS tab, you should have four options for the different Bar setups and if you have it supported it should have (RTT) listed next to it.
Then you'll have to reapply whatever Bar enhancement you had and copy all the modifications from your lasted tune to that one. Then just do a full rewrite into your pcm. I'm sure this sounds more confusing than it really is coming from me. It lists all this in the help files and is probably easier to understand.
Thanks Zick your explanation made more sense than the HP Tuners version. I was looking on the general tab under Engine tab. I have a question to all that have been messing with this...when i do this process it only gives me RTT on 1bar MAF enhanced, and not on speed density, since I only rune speed density right now does this mean I can only RTT with the MAF plugged in??? I am confused ???
#38
Wow, somebody understands me!
