how to turn off ses light on a 99 silverado
Old Aug 5, 2007 | 04:14 PM
bwillbblown's Avatar
Default how to turn off ses light on a 99 silverado
can you turn off the light without a scan-tool
Old Aug 5, 2007 | 04:19 PM
gmforlife's Avatar
unplug it from the back
Old Aug 5, 2007 | 04:27 PM
o really
Old Aug 5, 2007 | 04:29 PM
gmforlife's Avatar
i've heard guys do that, but from my experience, at least in the newer guage clusters they are sealed and only have one plug going to them, but you might be able to take it apart from the back side and just take the bulb out. Just my .02 It's easy to take out the cluster too, just take out the front part of the dash, it just clips in, and then drop your shifter into 1st if you have an auto and the cluster is held in with 4 bolts, and then just unplugs. Hope that helps.
Old Aug 5, 2007 | 04:41 PM
i just want to reset it
Old Aug 5, 2007 | 04:50 PM
gmforlife's Avatar
hmmm, don't really know how to do that, i know if it's a change enigine oil or something like that, it's turn the key to the "run" position, engine off, and depress the gas pedal 3 or 5 times within 5 seconds slowly and then ignition off. Try that, but like i said that's for engine oil on a trailblazer, but it might work. The only way that i know for sure is to clear the code with a scan tool, Tech II, if you have a friend with HPtuners or EFI Live or someone at a dealership.
Old Aug 5, 2007 | 04:59 PM
Grumpy5.3's Avatar
you might be able to go to your local parts house and see if they could check/clear your code!!!
Old Aug 5, 2007 | 05:01 PM
gmforlife's Avatar
if you go to autozone, you can rent one, they'll charge you on a credit card or something, but when you return it they refund you right away, so it's free.
Old Aug 7, 2007 | 12:47 PM
Blaydeman's Avatar
autozone will also just come out to your car and reset it for you.
Old Aug 7, 2007 | 12:58 PM
gmforlife's Avatar
there yah go!
