How much Timing??????
Old Apr 22, 2009 | 11:22 PM
getonit's Avatar
Default How much Timing??????
How much timing are you guys running and how much is to much???
Old Apr 22, 2009 | 11:54 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
on what setup? NA or FI? Nitrous, Turbo or Blown? You get my point....
Old Apr 23, 2009 | 12:06 AM
getonit's Avatar
N/A and nitrous with 93 octane on a fullbolt on lq4 with a 224/224 581/581 112
Old Apr 23, 2009 | 12:26 AM
Flaco's Avatar
8 Second Club
N/A i would be between 25-28 all motors are diff. TOO much would be around 35 or so more
NOS...all depends how much n2o....100 shot 24, 150 shot 22, 175 shot 19-20..200 shot 16-18, and so forth
Old Apr 23, 2009 | 09:06 AM
getonit's Avatar
Thanks for the info I think my tuner has way to much timing in my truck. It's hitting 40 degrees n/a. Do you think I am losing power that high?
Old Apr 23, 2009 | 09:08 AM
BlackGMC's Avatar
Resident Retard
Your hitting 40* at WOT or cruising? I am assuming cruising, cause 40* at WOT, this thread would be about you picking up pieces of your piston.
Old Apr 23, 2009 | 09:43 AM
TXsilverado's Avatar
compression plays in too. higher compression=lower timing.
Old Apr 24, 2009 | 09:24 AM
getonit's Avatar
A lq4 has like a 9:5 comp ratio
Old Apr 24, 2009 | 12:39 PM
budhayes3's Avatar
PT's Slowest Truck
That's your static compression ratio, your camshaft will affect your dynamic compression ratio...
Old Apr 24, 2009 | 02:49 PM
Wheatley's Avatar
Truck Sponsor
Thats right Stuart.Your on a role!!
If it 40 degrees at WOT you NEED to get that out of there.LOL
over 40 degrees in light throttle is normal though
