Histogram and speed density VE tuning help
#25
so with lambda cruising i want it to show 1.0 correct? in my map my stoich afr is 14.12414 which is what im told is correct for e10 fuel
i still cant figure out how to get my histogram to do like the link i posted in my OP. That deal talks about copying the histogram and being able to paste it to my ve map
#26
https://www.performancetrucks.net/fo...lambda-524099/
im tuning with lambda right now because im running e85.
also i try to use the Real time Tuning when ever possible. makes things super easy and fast.
I dont think my truck supports RTT? It would be under my OS options correct?
#29
i followed that post to a T, here are 2 screen shots let me know if you want to see any other ones
it seems HPT is a little off my my wideband but problem right now is my WB is still in AFR mode but its been 14.4-15.0 pretty much all in my crusing areas , i have a few that were mid 15's that im slowly dialing in
when my AEM gauge shows 14.7 the HPT scanner is showing like 1.02-1.03 lambda but its so hard to watch as they jump around alot. what would i need to alter to try to get it closer?
