High Idle in Park
Old May 6, 2015 | 02:35 PM
projectnightcrawler's Avatar
I put the tune roadkill attached in and the truck idled correctly for a little longer than normal than jumped up to 1600 rpms after about 15-20 seconds
Old May 6, 2015 | 02:43 PM
Atomic's Avatar
I have a gauge for that
Can you post up a hpt log of it when you start?
Old May 6, 2015 | 03:14 PM
The log of startup and quick drive it idles at about 1000-1100 in gear as well
File Type: hpl
Old May 7, 2015 | 07:14 AM
Atomic's Avatar
So it looks like when the timing comes in it goes up to that high value, but your tune needs major work otherwise. You have tons of KR in there when you give it throttle and your fueling is all over the place.
Old May 7, 2015 | 07:52 AM
RoadKill03's Avatar
I actually did the changes blind folded, just knew you had a cam but didn't know how big of a cam it was. Will look at the log and and make adjustments
Old May 7, 2015 | 05:23 PM
I replaced the IAC and TPS and now the truck idles where it should.
Old May 7, 2015 | 06:14 PM
I now have no oil pressure
Old May 7, 2015 | 08:56 PM
Atomic's Avatar
You sure you didnt unplug the sensor by chance? By no do you mean 0 or just really low?
Old May 7, 2015 | 09:19 PM
I changed to a new sensor checked again realy realy low pressure like 6psi put a mechanical gauge to it and once again about 6-8psi ive been told the oring going from the pickup to the pump is most likely the caust of the problem.
Old May 9, 2015 | 10:47 AM
Well just to give yall an update ive got to pull the motor and start over
gaps
Oct 15, 2015 02:53 PM
custm2500
Sep 8, 2015 05:53 PM
chvy=power
Sep 8, 2015 11:06 AM
montecarloss
Sep 2, 2015 04:44 PM
1slomax
Sep 1, 2015 11:05 PM
