HELP...Wires??? O2 Sensor
Ok working from memory here...
You should have 2 Grey wires, those are the heater wires.
The remaining 2 should be a lite color or white and a black. The black is the ground while the remaining would be your signal wire.
I hope this helps
I hope this helps
Originally Posted by knyznyk
What's the power wire (+12) then? I don't remember 5 wire.
LM7 and L59 Engine
Pin Wire Color Function
A TAN Low Signal Bank 2 Sensor 1
B PPL High Signal Bank 2 Sensor 1
C LT GRN Heater Low Control Bank 2 Sensor 1
D PNK Ignition L Voltage
