Help... truck wont idle below 1349RPMS
Old Feb 2, 2006 | 10:09 PM
ThunderZ28's Avatar
12 Second Club
yes and no..
I have been learning a ALOT lately..
some of it is very interesting,
it's a learning experiance tho..
Old Feb 2, 2006 | 10:10 PM
thunder550's Avatar
High on diesel fumes
Check your IAC wires. I had a similar problem and I found that the wires had melted to the EGR valve on the Radix. I know you don't have a charger, but your wires could still have gotten damaged. If that doesn't turn up anything try changing out your IAC valve.
Old Feb 2, 2006 | 10:22 PM
99Silver6.0's Avatar
Pintle can be stuck on the IAC motor too.
Old Feb 2, 2006 | 11:18 PM
ThunderZ28's Avatar
12 Second Club
after looking at the throttle body a bit..
I think the IAC motor is sticking on me...
it shows to be closed but it apparent it's not..
if it was closed then the engine should die, being that the IAC shows 0
going to try and change it out tomorrow, and see if it's the problem...
Old Feb 3, 2006 | 07:30 PM
Flyer's Avatar
Get a can of GOOD brake clean and try cleaning it up first. May save you some money.
Old Feb 3, 2006 | 07:33 PM
ThunderZ28's Avatar
12 Second Club
fixed it today..
wound up filling in the hole to the throttle body, and starting over...
IAC still reads 0 sometimes, but the idle is down to 650 or so
Old Feb 4, 2006 | 03:03 AM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Shouldnt the IAC be close to 60-80? Least thats what Allen was telling me while we were fighting the idle issues on my 418. Mine was bouncing up to 160 until we bent the tab on the throttle body.
Old Feb 4, 2006 | 08:05 AM
ThunderZ28's Avatar
12 Second Club
30 -50 should be the norm...
Mine is reading 0 but is idling fine..
it also idles fine with the ac on..
going to drive around a bit and see if it changes, if so I will make the necessary adjustments.
ThunderZ28's Avatar
12 Second Club
30 -50 should be the norm ...
Old Feb 4, 2006 | 10:40 AM
SSlow 4.8's Avatar
sounds good.. glad you fixed that
does it still do the thing where it wants to die when coming to a stop or did u fix all of tha too?
