HELP!! Power seat conversion
Old 11-18-2016, 01:12 AM
Rrodriguez13's Avatar
Default HELP!! Power seat conversion
Hello i just bought a pair of power leather seats for my 2005 single cab. I currently have power drivers seat but not the passenger seat. When i plugged them in tue drivers side worked fine but not the passenger if anyone has run across this same problem please let me know how you took care of it if you did TIA!
Old 11-18-2016, 10:30 AM
Custm2500's Rude Friend
1FastBrick's Avatar
My self, I install a harness from a power seat truck.
Old 11-18-2016, 10:46 AM
GM1697's Avatar
I ran a power/ground wire under my carpet from the driver's seat to the passenger.
Old 11-18-2016, 01:41 PM
Thanks for the feedback guys i will try to run power over from the drivers side. Do i tap into the original harness or did you run the wires directly to the seat? i thought it was going to be plug n play since mine already has the harness on the passenger side.
Old 11-18-2016, 01:46 PM
GM1697's Avatar
I tapped the harness coming out of the seat and just jumped across to the other seats plug, make sure to still plug in the passenger seat because of the airbag sensor
