Help Please!!!!
Old Nov 1, 2011 | 07:50 PM
regency's Avatar
Can i just do a write entire with a 02 tune i have and start retuning it, or is there some crap with the VATS i need to do, ive never done a OS change before
Old Nov 1, 2011 | 07:53 PM
GMCtrk's Avatar
I never had to do anything with VATS, it's simply an entire operating system recalibration. It takes around 3 minutes or so to complete, versus 30 seconds or so for simply flashing an updated tune.
Old Nov 1, 2011 | 07:59 PM
BlackGMC's Avatar
Resident Retard
If your not changing the injectors. Use the injector settings from the 99 since they are smaller
Old Nov 1, 2011 | 08:02 PM
Atomic's Avatar
I have a gauge for that
Whats the difference between the 99 and 02 os?
Old Nov 1, 2011 | 08:06 PM
BlackGMC's Avatar
Resident Retard
The 02 has better tables and is not prone to false KR like the 99
Old Nov 1, 2011 | 08:44 PM
regency's Avatar
Heres the table differences between the 99 and 02 i have in green, i copied the 99 to the 02 in pink but im not sure about the others in that section
Old Nov 4, 2011 | 05:22 PM
regency's Avatar
Ok so i tried to write this 02 OS into the 99 truck today and it would start and die over and over. So i then copied the tables to the 99 ecm and tried it, it started but only if u kept it running with your foot. Also it would start but with a cloud of pure white smoke. I just put the stock tune back in it an will try another day. I really need help now though, im lost in this after that episode!!!
Old Nov 4, 2011 | 05:28 PM
GMCtrk's Avatar
With HP tuners, don't you need to use an extra credit to do an OS swap?
Old Nov 4, 2011 | 07:35 PM
regency's Avatar
I have no clue. Also when i tried to change the VIN it would tell me something like invalid liscense and close the little screen. Both are liscensed through my software though....
Old Nov 13, 2011 | 09:08 PM
regency's Avatar
I would like for anyone to take a look at this and let me know what you think. I think its decent but i believe im getting false knock up to 5* but on the average its like 2*, it may be knock but it doesnt seem like it. I still needs more work on the VE but i didnt have time to finish up today. Timing is only increased by 4* from the stock table. I copied the High octane table to the low and added 4* to the High Octane table, which i dont think could have caused the knock unless i just dont have the VE dialed in close enough. This truck does have some 33" mud tires on it too, which i thought was causing some false knock, along with the roads around here.
File Type: hpt
File Type: hpl
File Type: cfg
