Help with my 370 tune!!! EFI live
Old May 25, 2008 | 01:31 PM
  #21
charcold-bowtie's Avatar
http://forum.efilive.com/showthread....ighlight=RAFIG
heres a link to a good rafig description.
Old May 25, 2008 | 01:44 PM
  #22
BlackGMC's Avatar
Resident Retard
On the RAFXX process I like to add in the Gear Selector (GM.PRND) PID so you can do the P/N and InGear at the same time. You can set up 2 Maps one for P/N and one for InGear, then you apply the following filters to the corresponding MAP.
Apply this filter to get the Park/Neutral values
Apply this filter to get the InGear values
Doing it this way you can do 1 cold start and fill in the table all at once...
Old May 25, 2008 | 01:54 PM
  #23
BlackGMC's Avatar
Resident Retard
Here are the two MAPs and PIDs that I use..
File Type: zip
Old May 26, 2008 | 08:37 PM
  #24
gao8302's Avatar
Ok. I did the Raf tuning and just did a autove. I just want to make sure i did this right and that im on the right track. Here are the tunes and the log. I am using the the mainve update tune now. The autove update is a the tune set up for autove with the changes from the autove log. I hope i did this right. It runs very well now but the trans and TQ convertor still need to be tuned. The truck will idle now and runs pretty good. I still think i have alot left in the tune. At least i hope so. Tell me what you think.
File Type: tun
File Type: tun
File Type: efi
Old May 26, 2008 | 09:49 PM
  #25
BlackGMC's Avatar
Resident Retard
The VE looks good, now you need to go back and remove the +10% you added to some of the cells you did not hit in your log... Also I would hand smooth a few of the spikes in the map. More than likely you need to do a few more AutoVE sessions to get the VE table dialed in... From what I have encountered if you use the full value of the BEN correction it tends to over shoot the desired AFR... I like to use a spreadsheet that allows you to only use a certain precentage of the BEN correction.. It helps get the AFR dialed in quicker.. You also might want to try lowering your idle down a little bit...
Old May 26, 2008 | 10:10 PM
  #26
gao8302's Avatar
Do you have the spreadsheet you are talking about? I also have to figure out TCC apply. The convertor trying to lock like it is stock.
Old May 26, 2008 | 10:12 PM
  #27
gao8302's Avatar
During the autove session i didnt get to high into the rpms because the wideband said i was getting lean.
Old May 26, 2008 | 10:25 PM
  #28
BlackGMC's Avatar
Resident Retard
I use the following spreadsheet. I usually use a 85% correction so I don't overshoot... Just paste your BENs from the log in the top section then copy from the third section and paste/multiple into your tune... Using the Interpolation usually works best with a stock smooth VE table. the Interpolation part helps keeps the VE table smooth...
File Type: zip
Old May 26, 2008 | 10:27 PM
  #29
BlackGMC's Avatar
Resident Retard
From the tune I looked at you had your PE table set to 14.6X, I like to autove with richer PE values..
Old May 26, 2008 | 10:28 PM
  #30
gao8302's Avatar
Damn i dont have that program to open it. What else can i do? Just use the smoothing function?
