help with error code p0122
Old Mar 27, 2006 | 10:50 PM
hog's Avatar
hog
Originally Posted by handchops
tried passkey relearn with no success. my security light goes out after only a couple of seconds. i still waited around about 11 mins after each attempt to start, but no luck on the forth start. worse yet i decided to change intake manifold gaskets after noticing a leak . just to find that two good sized portions of my manifold were gone due to corrosion. only 90k miles on this truck, i guess some one used the wrong coolent. what a suprise. new manifold on tuesday then back to the starting problem. anyone know where i can find torque values and pattern for my manifold that would be a big help. thanks in advance
The intake maniofld torque values are 11 lb/ft. The new GM gasket with the metal tabs and black sealing surfaces should help you out. Start in the midle then crossover back and forth across the intake towards the front and back of the intake.
Looks like Dexcool has eaten your manifold, I have seen Dexcool etch cast iron as well.
peace
Hog
Pimpinpete
43
Dec 22, 2017 08:13 AM
00loudchevy
Dec 3, 2015 05:54 PM
Avalanche2002
Nov 30, 2015 07:31 AM
bearden86
26
Nov 15, 2015 03:58 PM
Pimpinpete
Sep 8, 2015 07:39 PM
