Help? Converter not locking!
i didn't think they were an issue, just curious....my stockers are maxing out with just bolt ons and i saw his were are like 40% at high rpm, knew it had to be something. I'm sure his tune is more on than mine is too though.
2nd fastest 5.3 ECSB
Care to post up the tune so we can peak at your TCC settings?
I don't see anything that stands out to me on the log, but that isn't saying much...
I wish my DTC list looked like yours. Mine has about 3 or 4 times that many things in the list
and the best info I have been able to get is that none of them are anything to worry about.
and the best info I have been able to get is that none of them are anything to worry about.I have had those wheel speed sensor dtc's forever.
I don't know why your TCC is not locking but were you logging the TCC Mode Codes to see what was being commanded at the time of the runs or going from feel?
Most of those codes you posted look old and meaningless to me as far as your current problem is concerned. Erase them and see if you get any new codes. Does your converter lock under normal driving conditions? Maybe you are just making too much torque....
I cannot erase the DTC's...I click clear and they come right back. Am i doing it wrong?
Converter locks under normal driving as commanded.
I wish.
Heck maybe the nitrous wasn't working and that's the reason I was .4 slower..
I am not sure about HPT clearing codes. I use Autoenginuity or Tuner Cat to clear mine. None of those codes look like they are from the PCM but rather other modules and that may be why you cannot clear them. Do you know anyone with a Tech 2 that would clear them for you?
Maybe your TCC is wearing out? Anyway next time you run log your TCC Mode codes and TPS to be sure it is reading 100%. Maybe set your TCC to lock at the next lower %TPS as well to see if that helps. Have you changed to a different size tire that might throw your speed off? Is it possible that by lowering your shift rpm that the engine has a chance to get revving again before the TCC locks at 80MPH so that you do not notice a decrease in rpms when the TCC does lock?
Not sure about N2O but remember baby likes a warm and full bottle.
My buddy had problems with the converter coming unlocked. His issue was directly linked to his engine misfiring. Apparently, if the PCM senses X+1, 2, etc. number of misfires over the pre-determined number of allowed misfires, X, in a certain number of revolutions, the converter unlocks until the same number of revolutions can be repeated without the number of allowed misfires being over X.
For illustration purposes, say you allowed 9 misfires in 1500 revolutions. If the PCM detects 10 or more in 1500 revolutions, the converter will unlock until you go 1500 revolutions with 9 or fewer misfires.
Maybe its worth a shot. Have you checked anything to make sure you're not misfiring?
When my Yank let go, it would not lock under partial throttle or WOT when commanded so I feel your converter may be fine. I never got any codes.
I would start by lowering your TCC lock command a few notches lower than 100% TPS. I have seen where (for some odd reason) the converter would not lock unless it was lower than that figure. I know it doesn't make sense.
Also, by any chance did you tap the brake or have your left foot resting on the brake at any time?
