Help with Codes P0102 and P0327?
Old Jan 13, 2006 | 04:55 PM
digital's Avatar
Default Help with Codes P0102 and P0327?
2000 Chevy Silverado LT, 5.3 Vortec
Nelson Tune
Whipple blower with stock pulley
Throwing two codes,
1) P0102 - MAF/VAF circuit low
2) P0327 - Knock Sensor circuit (something like that)
Any insight anyone please?
California Smog now requires that any OBDII automobiles not have their SES light on during smog (according to the smog guy). I used to just hook up the scanner and dump the codes...
Old Jan 13, 2006 | 05:12 PM
02sierraz71_5.3's Avatar
Nelson Tune
Throwing two codes,
Are you using whipples electronics?
The SE light is everywhere with OBD 2 inspection
Old Jan 13, 2006 | 05:38 PM
digital's Avatar
No whipple computer,
using nelson tune...
Old Jan 14, 2006 | 08:05 PM
TG02Z71's Avatar
I got that same MAF code when I had some water in my intake tube.
After I cleaned and dried the MAF out it finally cleared.
Any chance you have some moisture in your intake or maybe oil from your filter?
You didn't really say what you did just before this happened.
Old Jan 17, 2006 | 05:45 PM
digital's Avatar
Could anyone tell me where to find the wire connector for the knock sensor on the back of the intake manifold on the Vortec 5.3L?
Thanks,
Old Jan 17, 2006 | 11:23 PM
thunder550's Avatar
High on diesel fumes
When you find the knock sensor harness, unplug it and gram an ohmmeter and test each sensor. They should be right at 100K ohms. If one is less than that you will have to replace it. Put one probe on the pin from the connector and the other try to touch the valley cover.
The plug for the knock sensors is on the back of the intake manifold by the firewall, and it has a little metal clip that holds it to the manifold. I think I posted in your other thread, but check out the Radix install instructions. They tell you how to pull the manifold and somewhere in there are pics of unplugging the knock sensors.
http://www.magnacharger.com/pdf/manu...SUV1999-02.pdf
Old Jan 18, 2006 | 08:41 PM
digital's Avatar
Awesome reply Thunder550, that's exactly what I was looking for...
Thank you
Old Jan 19, 2006 | 12:04 AM
thunder550's Avatar
Glad I could help
Pimpinpete
43
Dec 22, 2017 08:13 AM
00loudchevy
Dec 3, 2015 05:54 PM
Avalanche2002
Nov 30, 2015 07:31 AM
bearden86
26
Nov 15, 2015 03:58 PM
Pimpinpete
Sep 8, 2015 07:39 PM
