Help with codes
Old Mar 19, 2006 | 10:48 AM
Default Help with codes
I'm setting off code's P0137 and P0157= circuit low voltage Bank 1 Sensor 2 and circuit low voltage Bank 2 Sensor 2. Does anybody know if this is caused from to much fuel under WOT as this is when it usually set's the code? Thanks
Old Mar 19, 2006 | 11:36 AM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Bad rear o2s. Most likely from the pressurized exhaust track or from being too rich all the time (but it would be waaay to rich -- black smoke and a missing feel)
Old Mar 19, 2006 | 11:44 AM
What would be the solution??
Old Mar 19, 2006 | 06:26 PM
anybody?
Old Mar 19, 2006 | 07:46 PM
I AM A MOTHERF*CKER
You can have allen just turn off the rear o2s or replace them with new sensors. Personally, I'd turn 'em off as they are just going to die again.
Old Mar 19, 2006 | 09:34 PM
1slowsilverado's Avatar
99% of the time its just the sensor itself. Take a peak under there and make sure the wire is not melted some where. This is a lean condintion, If post cat 02's stay under 400mv (dont quote me) +or- during PE for 5 sec or more you will though this code. This is just a post cat monitor anything major should show upstream if this were true. So most likely its just the 02 sensor or its shorted out somewhere.
Pimpinpete
43
Dec 22, 2017 08:13 AM
00loudchevy
Dec 3, 2015 05:54 PM
Avalanche2002
Nov 30, 2015 07:31 AM
bearden86
26
Nov 15, 2015 03:58 PM
Pimpinpete
Sep 8, 2015 07:39 PM
