Help with code C0265
Old May 13, 2009 | 10:23 PM
budhayes3's Avatar
PT's Slowest Truck
Originally Posted by lady3bglover
OMG... this is the same crap that I'm going through as we speak.
Eric showed me where to check the module and the connections under the truck, the ground, and the fuses, and tonight I went to NTB to have one of the guys check the ABS connections and all was good. Then he checked the coding. The first was C0238 which said "Wheel Speed Mismatch", and the second code was C0265 which is the "ECBM Relay Circuit". The tech at NTB told me that replacing the relay should clear the issue, but there's no promise. Now since we checked the fuses, the system hasn't coded, but I will continue to get what needs done, done.
So I'm hoping that replacing the relay circuit will cure my coding. Now I have to find the circuit. If this doesn't correct the issue, which I'm praying that it does, I may have to make the $1100 purchase which I'm not looking forward to.
Fireman31, thanks for the info... )
If you end up needing an EBCM, check google and/or ebay for modulemaster.com. He used to repair your existing module for around $100...may be up to $150 by now...
Old Dec 18, 2014 | 06:53 PM
Tahoe02's Avatar
Registered User
Thanks a lot!! New to the thread... but just fixed my issue 20 mins ago by cleaning the ground like suggested in here. Got my truck back from getting regeared with 4.88 gears and the abs light and brake light have been on ever since...with two codes c0265 and c0238 have a 3" body lift so access to the ecm was easy, was about to pull it out and solder it up till I read this, saved me a bunch of trouble for nothing!! Thanks again
Old Dec 18, 2014 | 07:22 PM
fordbug77's Avatar
Default abs
Check out module masters. I've sent a couple EBCM to them to rebuild and it was cheap. Less $200
Pimpinpete
43
Dec 22, 2017 08:13 AM
00loudchevy
Dec 3, 2015 05:54 PM
Avalanche2002
Nov 30, 2015 07:31 AM
bearden86
26
Nov 15, 2015 03:58 PM
Pimpinpete
Sep 8, 2015 07:39 PM
