Head/Cam swap w/o tune... did I cause damage?
Old 11-10-2012, 04:42 PM
Ferocity02's Avatar
Default Head/Cam swap w/o tune... did I cause damage?
A few weeks ago I swapped in a 212/212 0.561/0.561 114LSA cam and stock 799 heads milled 0.022 to retain the factory 9.5:1 SCR. Before this the truck had an LS1 cam and stock 706 heads with a mail order tune. The tune has not been altered for the new cam and heads. It slipped my mind that the new parts should need a new tune. I have taken the truck to redline just a handful of times since the swap and was wondering if perhaps I have caused damage?
The new cam and heads aren't terribly larger than what was in there. The engine runs fine but has an annoying metal tapping sound coming from around cylinder 5 or 7. I pulled the valve cover and didn't see anything. No exhaust leaks. The lifters are fairly new with 0.075" preload. Oil pressure is great. No codes other than for the EGR which I removed. Could I have toasted a piston or rings? The tapping sound is hit and miss. I put it on jacks yesterday to investigate and the tapping sound was pretty much gone, then I noticed it again when driving home. The tapping seems to be at half the speed of the engine.
Thanks!
Old 11-10-2012, 05:40 PM
GMCtrk's Avatar
I highly doubt you hurt it. That being said, going WOT without it tuned was not the best idea.
Old 11-10-2012, 05:50 PM
Ferocity02's Avatar
Yeah it totally slipped my mind. I'm overly paranoid so I may to a compression test just to confirm.
Old 11-11-2012, 11:43 AM
traveling mod
andrew383's Avatar
Did you change valve springs also?
Old 11-11-2012, 12:54 PM
Ferocity02's Avatar
Yup, dual springs.
Old 11-11-2012, 11:30 PM
Registered User
turbo-ls7's Avatar
Could be a wrist pin slapping the side wall had this happen to me a few months back on a 6.2 just a thought
Bluecollar Hotrods
03-13-2017 05:02 PM
1bad2k
08-26-2015 07:42 AM
Jake75
08-05-2015 01:26 PM
low2001gmc
07-21-2015 02:09 PM
chevy1224
07-13-2015 07:50 AM
Quick Reply: Head/Cam swap w/o tune... did I cause damage?
