Have ses light need help please
Old Jan 21, 2013 | 06:01 PM
  #21
tiffo60's Avatar
Originally Posted by Medic/Z28
Ok still haven't taken the pics. Busy weekend and now at my night job so.... Anways it still runs like CRAP. Actually died today when it was at idle at home. So idk. It performs ok when I'm driving. I changed the oil in it the night before last so I could driving it hard and aggresive too see if I can't shake "it" (SES light) off like a horse with a bad habit but no success. I did call the tuner. No answer of course. How hard is it to tune yourself if you buy the software? How much does that run?
Its not hard, just a lot of information to take in a first. Once you get a grasp on the concept all the information you read starts to make since. You will also be able to sift thru the crap from the relevant information. I think figuring out the 6L80 was more time consuming the the engine tuning. Greg Banishes DVD's are great for newbie's
Old Feb 7, 2013 | 06:21 PM
  #22
Medic/Z28's Avatar
***UPDATE*** Ok so I've been trying to get ahold of the tuner but he hasn't answered my emails, messages, phone calls or phone messages. My truck idles like crap, it dies at traffic stops. Last night I was driving and it died on me. It rides like ****. A co-worker asked if I'd put a cam in the bitch it idles so bad. I took it to O'Reilly's to check the codes and it through 16 codes. SIXTEEN CODES!!! I need the retune. Meantime any one have any ideas???
Old Feb 7, 2013 | 09:33 PM
  #23
Medic/Z28's Avatar
By the way here is the list of codes:
030
050
053
059
P0131
P0135
P0151
P0155
Now these were codes popped out twice so thats why it was 16 of them. But seriously what gives?
Old Feb 8, 2013 | 11:16 AM
  #24
Suburbazine's Avatar
030
050
053
059
P0131
P0135
P0151
P0155
It had both pending and set codes. That's why you got double codes.
131 and 151:
CIRCUIT DESCRIPTION
This diagnostic applies only to vehicles built with case grounded heated oxygen sensors (HO2S). In order to identify the HO2S, refer to Computers and Controls Systems Component Views.
The powertrain control module (PCM) supplies a voltage of about 450 mV between the HO2S high and low signal circuits. The HO2S varies the voltage over a range of about 1,000 mV when the exhaust is rich to about 10 mV when the exhaust is lean.
The PCM monitors and stores the HO2S voltage information. The PCM evaluates the HO2S voltage samples in order to determine the amount of time the HO2S voltage was out of range. The PCM compares the stored HO2S voltage samples taken within each sample period and determines if the majority of the samples are out of the operating range.
The PCM monitors the HO2S voltage for being fixed below a predetermined voltage. If the PCM detects the voltage is below a predetermined voltage, a diagnostic trouble code (DTC) sets.
CONDITIONS FOR RUNNING THE DTC
  • DTCs P0101, P0102, P0103, P0106, P0107, P0108, P0112, P0113, P0116, P0117, P0118, P0121, P0122, P0123, P0200, P0300, P0401, P0404, P0405, P0440, P0442, P0446, P0452, P0453, P1120, P1125, P1220, P1221, P1258, P1404, P1441, P1514, P1515, P1516, P1517, or P1518 are not set.
  • The vehicle is operating in Closed Loop.
  • The ignition 1 signal is between 9-18 volts .
  • The fuel tank level remaining is more than 10 percent.
  • Intrusive tests are not in progress.
  • The scan tool output controls are not active.
Lean Test Enable:
  • The air fuel ratio is between 14.5:1-14.7:1.
  • For vehicles with throttle-actuated control (TAC), the throttle position (TP) indicated angle is between 3-70 percent more than the value observed at idle.
  • For vehicles without TAC, the TP is between 3-70 percent .
Power Enrichment Test Enable:
  • Power enrichment is active.
  • The above condition is met for 1 second .
CONDITIONS FOR SETTING THE DTC
Lean Test:
The HO2S voltage is less than 200 mV for 165 seconds .
Power Enrichment Test:
The HO2S voltage is less than 360 mV for 10 seconds .
ACTION TAKEN WHEN THE DTC SETS
  • The control module illuminates the malfunction indicator lamp (MIL) on the second consecutive ignition cycle that the diagnostic runs and fails.
  • The control module records the operating conditions at the time the diagnostic fails. The first time the diagnostic fails, the control module stores this information in the Failure Records. If the diagnostic reports a failure on the second consecutive ignition cycle, the control module records the operating conditions at the time of the failure. The control module writes the operating conditions to the Freeze Frame and updates the Failure Records.
  • The control module commands Open Loop.
CONDITIONS FOR CLEARING THE MIL/DTC
  • The control module turns OFF the malfunction indicator lamp (MIL) after 3 consecutive ignition cycles that the diagnostic runs and does not fail.
  • A current DTC, Last Test Failed, clears when the diagnostic runs and passes.
  • A history DTC clears after 40 consecutive warm-up cycles, if no failures are reported by this or any other emission related diagnostic.
  • Clear the MIL and the DTC with a scan tool.
DIAGNOSTIC AIDS
IMPORTANT: Remove any debris from the PCM connector surfaces before servicing the PCM. Inspect the PCM connector gaskets when diagnosing or replacing the PCM. Ensure that the gaskets are installed correctly. The gaskets prevent water intrusion into the PCM.
  #25
135 and 155:
CIRCUIT DESCRIPTION
This diagnostic applies only to vehicles built with case grounded heated oxygen sensors (HO2S). To identify the HO2S, refer to Computers and Controls Systems Component Views.
The powertrain control module (PCM) supplies a bias voltage of approximately 450 mV on the HO2S signal high and low circuits. When you turn the ignition to the ON position, battery voltage is supplied to the HO2S heater. As the heater reaches the operating temperature, the HO2S voltage responds by changing from a bias voltage range to the normal operation. Typically, as the HO2S reaches the operating temperature, the HO2S voltage goes from a bias voltage to a voltage below 300 mV . Depending on the exhaust gas content, the HO2S voltage may go above 450 mV .
The PCM runs the heater test only on a cold start, depending on the cumulative air flow, and only once an ignition cycle. When you start the engine the PCM monitors the HO2S voltage. When the HO2S voltage goes above or below the bias range threshold, the PCM determines how much time elapsed. If the PCM detects that the process took too much time for the HO2S to enter into normal operating range, a DTC sets. The time the process takes the HO2S to reach operating temperature is based on the amount of air that flows into the engine.
  • DTCs P0101, P0102, P0103, P0106, P0107, P0108, P0112, P0113, P0116, P0117, P0118, P0121, P0122, P0123, P0131, P0132, P0134, P0137, P0138, P0140, P0151, P0152, P0154, P0157, P0158, P0160, P0200, P0300, P0401, P0404, P0405, P0440, P0442, P0446, P0452, P0453, P1120, P1125, P1220, P1221, P1258, P1404, P1441, P1514, P1515, P1516, P1517, or P1518 are not set.
  • The HO2S voltage is between 425-475 mV at engine start-up.
  • The intake air temperature (IAT) and the engine coolant temperature (ECT) are less than 50°C (122°F) and are within 8°C (14.5°F) of each other at engine start-up.
  • The mass air flow (MAF) is less than 25 g/s .
DTC P0135 or P0155
The HO2S voltage remains within 150 mV of the start-up voltage for a predetermined amount of time, based on ECT and air flow.
DTC P0141 or P0161
The HO2S voltage remains within 75 mV of the start-up voltage for a predetermined amount of time, based on ECT and air flow.
DIAGNOSTIC AIDS
  • Using the Freeze Frame/Failure Records data may aid in locating an intermittent condition. If you cannot duplicate the DTC, the information included in the Freeze Frame/Failure Records can help determine how many kilometers (miles) since the DTC set. The Fail Counter and Pass Counter can also help determine how many ignition cycles the diagnostic reported a pass or a fail. Operate the vehicle within the same Freeze Frame conditions such as RPM, load, vehicle speed, and temperature that you observed. This will isolate when the DTC failed. For an intermittent condition, refer to Intermittent Conditions. See: Powertrain Management\Computers and Control Systems\Testing and Inspection\Initial Inspection and Diagnostic Overview\Diagnostic Strategies\Intermittent Conditions
  • The heater diagnostic will only run on a cold start and run once per ignition cycle.
  • An oxygen supply inside the HO2S is necessary for proper operation. The HO2S wires provide the supply of oxygen. Inspect the HO2S wires and connections for breaks or contamination. Refer to Heated Oxygen Sensor (HO2S) Wiring Repairs in Diagnostic Aids.
Old Feb 8, 2013 | 11:19 AM
  #26
The 0030 and other 2-digit codes indicate a heater circuit error. Maybe you cut a wire by accident or burned out the PCM switches?
Old Feb 9, 2013 | 11:48 PM
  #27
Medic/Z28's Avatar
Thanks I'll read these and try to make sense of all this info. I'm not one who understands how curcuits and tunes work so they'll be a lot googling going on.
Old Mar 5, 2013 | 10:42 AM
  #28
Medic/Z28's Avatar
Whoever suggested to use C5 rear O2 sensors totally doesn't know what they're talking about. That's why i had 24 yeah 24 codes going off. Issue fixed. Tuner and I finally got in contact and got it straightened out. SO far so good.
RustyD
May 23, 2016 07:04 PM
dantheman1540
Feb 24, 2016 09:56 PM
Avalanche2002
Nov 30, 2015 07:31 AM
legerwn
56
Nov 15, 2015 10:21 PM
carid
Oct 1, 2015 09:22 AM
