has anyone on here done a DBW to DBC conversion?
Old Sep 3, 2011 | 12:15 PM
kbracing96's Avatar
The little info I know about this... 03-07 DBW PCM does not have a controller for a IAC, so you have to use a 99-02 PCM and repin everything to make it work. But like Dan said, Allen has done it a few time's so you should talk to him.
Old Sep 3, 2011 | 12:34 PM
CalEditor@PCMCalibrators's Avatar
FormerVendor
Some PCM all the way up to 2007 have IAC drivers
Old Sep 3, 2011 | 05:22 PM
Gadgetized's Avatar
I wanted to keep my DBW, but I have had problems since the 87/90mm conversion. I am actually leaning towards a bad X-link now. I have horrible luck, and if there was 1 bad one out of 10,000 I guarantee I would be the one to get it. My codes have gotten worse with time, and all my wires looked and tested to be OK. I had my truck at my fathers shop about 20 miles away from my house, and it started going into REP as soon as I turned the key. He let me borrow a truck, and I am very thankful for that. I was just mad that I had to use one of his trucks to drive home when I should have just worked on it in my garage. Well today when I was at work I remembered that I still had my 78mm DBW T-body kicking around at my house. I decided to plug it in to the 8 pin plug, and see if I get codes. Well I didn't get any codes. I swapped both my 87, and 90mm T-bodies on, and got the same codes again. I was bound and determined to drive my truck home because I hate the feeling of having to borrow something from my parents at my age. Well what does someone do when they have a working 78mm 3 bolt flange T-body, and a 4 bolt flange to mount it on? You guessed it, look for duck tape!! Well it idled a little high, but I never threw a code.
Old Sep 3, 2011 | 05:56 PM
AndysC3's Avatar
nice.
at least you could drive it again. So you gonna try a new x-link?
Old Sep 3, 2011 | 06:19 PM
Gadgetized's Avatar
Yeah, I think I will try a new one. I have been emailing them about it.
Old Sep 3, 2011 | 06:27 PM
BlackGMC's Avatar
Resident Retard
That is a new use for duct tape.
Old Sep 6, 2011 | 10:47 AM
EVILGMC's Avatar
seems we are having similar if not the the same problem.
what specific codes are you experiencing?
Any input from Nelson?
Old Sep 6, 2011 | 12:32 PM
Gadgetized's Avatar
PM sent EVILGMC.
Old Sep 6, 2011 | 12:50 PM
BlackGMC's Avatar
Resident Retard
Couple of questions.
Did you update the tune for the bigger TB?
When did the problem start?
Have you tried replacing the PCM?
Old Sep 6, 2011 | 01:03 PM
EVILGMC's Avatar
I have had this TB for years, and gives same symptoms when I try a different one.
Problem started during burnout of my 10th pass at a track day. Was intermittent at first...then 100% FUCKED
I am looking for a spare PCM and also a local solution to get my tune into it (dont have tuning software or a bench harness)
Not trying to jack this thread....but seems like we are fighting similar battles.
