Ground wire locations
Old 09-22-2012, 02:31 PM
Registered User
Team Paulie's Avatar
Default Ground wire locations
On the rear of the block,all of the ones that go behind the intake,do two wires go to the same spot or do each of them do to their own? Pics? websites?
2004 LQ4 swapped 6.0 into a RCSB 2004 silverado formerly a 4.8,with a LS package, I had a chilton manual and have sense lost track of it.
Also will the 6.0 starter work with the stock 4.8 flywheel,it bolted up the same,and upon looking at the two of em side by side they look identical,the 4.8 starter has seen better days and the 6.0 is brand new.
Old 10-02-2012, 03:45 PM
Registered User
Anybody????Please???
Old 10-02-2012, 03:50 PM
Mod with training wheels
smokeshow's Avatar
Theres a single ground strap from cylinder head to firewall
Old 10-02-2012, 06:19 PM
rkwhite61's Avatar
Not sure about an '04, but on my '02 harness, the wiring harness should have one on the head or tranny bolt on both sides of the motor. Then there is the ground strap from the head to the firewall. I believe that's it for grounds on the rear of the engine area. Hope this helps.
Old 10-02-2012, 07:47 PM
Registered User
Thats what I was thinking too,so I'm just go run em all to their own spots.
Old 10-05-2012, 01:55 PM
Registered User
Do two grounds both go to the same spot?
Old 10-05-2012, 02:49 PM
2000chevysilverado's Avatar
You can run two grounds same spot shouldn't make a difference
Old 10-05-2012, 03:31 PM
Registered User
I have the two of those going to the bolt next to the cam sensor and the braided one is on the back of the block going up to the stud on the firewall.
Old 10-05-2012, 04:21 PM
TXSZ66AVLANCHE's Avatar
Good gawd just bolt them grounds to something metal and call it done.
Old 10-05-2012, 06:20 PM
DR132's Avatar
exactly, as long as you have solid grounds going from the block to the chassis and the battery in some fashion you'll be fine. it won't matter if you end up having several grounds stacked up on one fastener.
Quick Reply: Ground wire locations
