Got a problem, Help!
Old Oct 16, 2008 | 03:46 PM
Raffman's Avatar
Default Got a problem, Help!
Been getting a trouble code for right O2 sensor, reset it and it comes back.
Was out for a cruise today and got on it and had a slight bog up top and it started skipping . Scanned it and got 3 strange codes: PO327 knock sensor bank 1 low input, PO332 knock sensor 2 low input, and P1637 CAN LINK ECM/ABSCM circut network malfunction. Also heard a strange noise that went away. Any ideas?? Going to pull the plugs when it cools down and have a look. Wonder if It bent a push rod? right now I have no idea.....HELP
Old Oct 16, 2008 | 03:50 PM
viciousknid's Avatar
Where's the Beef?
Did you fix the Sensor?
Old Oct 16, 2008 | 04:09 PM
Raffman's Avatar
They are both brand new LS6 sensors, wires are all good
Old Oct 16, 2008 | 04:11 PM
Raffman's Avatar
Originally Posted by Raffman
They are both brand new LS6 knock sensors, wires are all good
No I haven't replaced the O2 yet.
Old Oct 17, 2008 | 07:24 AM
Raffman's Avatar
Anyone?
Maybe I should rephrase. What would cause those codes to trip? and what the hell is that P1637 code about?
Old Oct 17, 2008 | 08:03 AM
NoChrome's Avatar
I would chase the o2 sensor first, its almost certainly bad and then start chasing other stuff because those faults could be related to the fuel the o2 sensor is trying to compensate with.
Old Oct 17, 2008 | 03:31 PM
Raffman's Avatar
OK problem fixed. Two spark plug wires burned on the headers and the bad O2 sensor combined did it. That code P1637 guess is because of the tune but everything cleared and I'm off to the strip tonight. Last night for test & tune for the season and first run with the new motor, a good nite will be if I drive home after with no problems.........
madmann26
Apr 29, 2020 09:17 AM
dsbodley
Nov 14, 2015 09:46 PM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
sTNT971
Sep 26, 2015 06:27 AM
