Got a problem with DOD removal
i have a truck that we did a cam swap in. we removed the lifters and replaced them with ls7 lifters and removed the whole dod setup. the truck was previously tuned for a cam a little bit bigger then this one. should the truck idle if the dod settings have not been removed thru the hp tuners?
i logged the truck and it shows a 15* underspeed and overspeed then it flattens out at 24* and starts to drop idle then turns off.
truck is throwing a u0100
when the vehicle is off and the scanner is running it shows 30% tps, i dont think this is normal
I don't think it's possible for the engine to go into DOD while idling. On my '09 there is a minimum VSS of 14mph for the DOD. Although different years could have different settings... I'd turn of DOD in your case, hell I actually did just turn off DOD on the '09 today.
SlvrSierra4.8
Oct 1, 2015 09:39 PM
MA$TER_E
Sep 9, 2015 03:14 PM
