Gen 4 limiting as 2-step limiter?
Old Sep 8, 2015 | 11:46 PM
elir_mn's Avatar
Default Gen 4 limiting as 2-step limiter?
Someone has set up a GMT900 Silverado with HP Tuners, so do Cut off as a traditional 2-Step or Gen 3, referring to short pauses that make the launch control as well as "pa pa pa pa"
All feedback is welcome, thanks
Old Sep 9, 2015 | 09:59 AM
Atomic's Avatar
I have a gauge for that
Is this a question or a statement?
Old Sep 9, 2015 | 10:21 AM
1bad2k's Avatar
Old Sep 9, 2015 | 10:35 AM
FFDP's Avatar
I'd just assume a question and that his english isnt perfect given where he is from. I think he'd like to know if a GEN 4 computer and 2 step just like a GEN 3??
Old Sep 9, 2015 | 04:18 PM
norris_83's Avatar
it certainly can do..
Old Sep 16, 2015 | 08:39 PM
elir_mn's Avatar
Thanks for the help. What I mean is that in a Gen4 activate the cutoff, ignition cut as if installed a 2-step limiter as well as a few quick cuts "Papapapá"
Old Sep 17, 2015 | 12:25 PM
terravast4's Avatar
what?
Old Sep 17, 2015 | 12:59 PM
03regcab sierra's Avatar
I think he is referring to the rev limiter being different from the older models which had a hard cut so it sounds like a 2 step. The newer drive by wire throttle body has a soft rev limiter so it sounds like it pauses at the desired rpm of the rev limiter. I do believe you can change that with hp tuners. I don't see the exact point to this post though...
Old Sep 19, 2015 | 11:43 AM
elir_mn's Avatar
If that is what I mean, I've disabled the cutoff by the Electronic throttle and shift the cutting method Spark / Fuel, just cutting breaks are so close together they almost unnoticeable
FlowmasterMufflers
Nov 24, 2015 01:00 PM
zblee
Nov 11, 2015 12:41 AM
TAPyvehc93
Sep 14, 2015 01:22 PM
FlowmasterMufflers
Sep 11, 2015 03:32 PM
