Gauges Gauges and Gauges!!!!
Looking into getting the radix charger. gonna need some gauges.. Fuel, Boost, and Tranny. which ones are you guys running? prob will get autometer. I understand how to hook up boost and fuel pressure. Where does the tranny gauge hook up???
Probably better to do a wideband gauge since your boosted. I run wideband, boost and an interceptor scan gauge. The pcm logs trans temps so when you plug in the scan gauge you can read it without needing to tap anywhere for the sender. You can also buy the sender for fuel pressure and hook it up to your scan gauge. And the scan gauge monitors two settings at the same time so you can watch both trans temp and fuel pressure.
Thats the guy I picked them up from, was by far the cheapest, not sure about now, but when I was shopping he def was..
