-   Tuning, Diagnostics, Electronics, and Wiring (https://www.performancetrucks.net/forums/tuning-diagnostics-electronics-wiring-161/)
-   -   Gauge cluster wiring schematic??? (https://www.performancetrucks.net/forums/tuning-diagnostics-electronics-wiring-161/gauge-cluster-wiring-schematic-491289/)
Phantom Oct 31, 2011 05:46 PM
Anybody have one or a link to one? 2003-2007 classic silverado. Thanks
LsF-150 Oct 31, 2011 06:50 PM
PM me if you need something better...:cheers:btw those are for my 06 crew cab
Phantom Oct 31, 2011 06:57 PM
WOW! That's probably really great info for someone who knows how to read those things lol. I'm just looking for what each wire does...Mainly looking for:
bright lite indicator
turn signals (left and right)
speedometer
service engine light
Phantom Oct 31, 2011 07:17 PM
and fuel level
01WS6/tamu Oct 31, 2011 08:04 PM
High beam indicator, and fuel level signal come off of the serial data bus. These are not hard wired functions.
VSS dk gn/wht term A4 at IPC
MIL bn/wht
Phantom Oct 31, 2011 08:08 PM
Has to be some way to get a reading for the fuel level right? Maybe off the wiring harness on the tank?
SnakeOiler Oct 31, 2011 08:24 PM
So you would want the pinout of the I/P connector?
Phantom Oct 31, 2011 08:25 PM
Perhaps? I'm not real good with my wording. You all should just know what I mean lol
I would like to know what wires do what on the plug that plugs into the back of of the cluster
01WS6/tamu Oct 31, 2011 08:28 PM
The fuel level signal is processed by the pcm it sends 5 volts to the sender and gets a level reading in return. This is information is processed by the pcm then sent to the instrument cluster via serial data over the data bus there is not a hard wired fuel gauge input. What kind of vehicle is this in are you converting something or is it all in a stock application.
Phantom Oct 31, 2011 08:31 PM
It's on my truck. 2007 classic chevy silverado. Installing aftermarket fuel level gauge.
How bout this? Couldn't I get the signal from the wire directly off wiring on the tank?
