Gas smell and P0440
Old Jan 31, 2012 | 01:27 AM
kr1s's Avatar
Default Gas smell and P0440
I'm getting a nasty gas smell, its been there since i replaced the sending unit
I checked my fuel lines and my filter and nothing, i filled my tank and i got the p0440 code any ideas?
Old Jan 31, 2012 | 01:32 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Check the evap lines instead of the fuel lines. They are plastic and fairly easy to break without knowing.
If your transmission has been out, I've seen a couple of them with broken lines between the left cylinder head & firewall. Otherwise look back by the charcoal cannister.
Old Jan 31, 2012 | 01:43 AM
kr1s's Avatar
Remember when i did the swap? The Evap thing with the green cap was left off, could that be a problem?
Where would the charcoal canister be?
And Maybe when i dropped my gas tank? Not literary but like i took it down.
Will this hurt performance or anything? Cause if not ill worry about it later when i'm upgrading my fuel pump
Old Jan 31, 2012 | 01:47 AM
Won't affect performance at all. It's the evap system, it basically purges fuel vapors from your gas tank into the intake manifold while you're driving, instead of into the atmosphere.
Basically, you're a polluter until you fix it. lol
Old Jan 31, 2012 | 01:48 AM
Oh, the cannister is under the truck, just to the front of the tank on the driver's side. There's a line that goes from the tank to the cannister, so check that also.
Old Jan 31, 2012 | 02:06 AM
kr1s's Avatar
Lol Ill look more into it tomorrow.
For now i think ill just turn off the Mil Enabler for that code. I hate seeing the check engine on
Thanks man!
Old Jan 31, 2012 | 10:06 AM
Ferocity02's Avatar
I have been getting the same code with too a slight raw fuel smell... It has not come back yet, but I'm not sure the truck has done its EVAP check yet. I heard it only does it between 3/4 and 1/4 tank of fuel.
Has your gas mileage changed at all? Mine's gone south.
Let me know what you find!
Old Jan 31, 2012 | 05:35 PM
kr1s's Avatar
Ill reset the code today, fill up and see if i'm leaking around the gas tank or anywhere. And as far as mileage goes umm... ehhh its okay lol i have never actually payed attention to how much i've gotten but 1/2 a tank will last me the week and i drive quite alot
Old Jan 31, 2012 | 07:15 PM
Alpinestar's Avatar
I would say that your problem has something to do with the gas tank system but you might check your PCV lines also. My PCV system is just venting to the atmosphere and it defiantly smells at a stop light. BTW when you do the fuel pump I would just pull the truck bed off if you had some help.
Old Feb 20, 2012 | 12:52 AM
kr1s's Avatar
I found out that it was my fuel lines that go into my intake manifold!!!! They weren't screwed in all the way Well i didn't have my Hose clamps tight enough and fuel was leaking out I need to do something with the A/N fittings.
It is just braided steel lines with clamps on them
Pimpinpete
43
Dec 22, 2017 08:13 AM
bearden86
26
Nov 15, 2015 03:58 PM
turbo6c3
Oct 5, 2015 06:11 PM
sTNT971
Sep 26, 2015 04:22 PM
nic351
Sep 24, 2015 09:43 AM
