False KR?!
Old May 26, 2016 | 05:26 PM
defconfire's Avatar
Registered User
Default False KR?!
I've noticed an issue with KR today and I'm not sure if its a genuine problem or if its false knock from another source. It seems to happen mostly around (after) shifts but there were a few exception.
Being that this is a FI car I really do not want to turn down the gain on the knock sensors unless I have to.
The setup is a bone stock 5.3 (lmg) with a 76mm on3 turbo kit and 850cc FAST injectors, running very rich.
I've attached my tune and a few logs.
File Type: hpl
File Type: hpl
File Type: hpl
File Type: hpl
Old May 27, 2016 | 03:49 PM
defconfire's Avatar
Registered User
anyone?
Old May 27, 2016 | 05:49 PM
Last Call's Avatar
TOTM: January 2007
Looking at your high octane map, you are actually adding 2 degrees (from 12 to 14) of timing when you from 1.67 to 1.80 down in the 4200 column. Smoothing it out and removing a few degrees may help. However that does not explain the KR at 4800 rpm. Can you log per cylinder (A-H) KR?
With 10 degrees of timing, running as rich as you are, and 9.5 compression, I don't think it's real KR. You can try adding a few gallons of race gas to see if it goes away.
Old May 27, 2016 | 06:41 PM
GMCtrk's Avatar
factory settings for the knock sensor sensitivity is way too high for a modified setup. I would at minimum use the settings from a c5 Z06.
Use at your own risk. JMO.
Old May 27, 2016 | 06:54 PM
BlackGMC's Avatar
Resident Retard
Intereting. I have actually made mine more sensative.
Old May 27, 2016 | 07:05 PM
FFDP's Avatar
GEN 4 computers are little different than older GEN 3 computers that for sure.
Kinda crazy how much predicted knock and knock sensor sensitivity they put in them from the factory.
Old May 27, 2016 | 08:33 PM
madmann26's Avatar
Last Call is referring to rich knock.
Wherever you see KR, subtract that amount in the corresponding high/low spark settings.
If it goes away, it's real. If it stays, it's false.
MikeD.
May 13, 2016 09:43 PM
SloStepSide
Apr 2, 2016 04:20 PM
droppedchev
Mar 14, 2016 05:42 AM
GM1697
Mar 10, 2016 06:53 AM
98silvermaro
Feb 26, 2016 11:47 PM
