Engine holds at 5,500 rpm on WOT.. any suggestions?
Old Oct 11, 2011 | 11:57 PM
TXjeepTJ's Avatar
Default Engine holds at 5,500 rpm on WOT.. any suggestions?
Would this be tune related? Fuel pump is holding pressure
5,500 RPM holding - YouTube
Old Oct 12, 2011 | 12:19 AM
TXjeepTJ's Avatar
Also, it didn't do this before I installed a 3000rpm stalled converter and the new PCM for the converter. Here is a video of how it ran before the converter
Turbo 5.3L w/ 4L80E and STOCK STALL - YouTube
Old Oct 12, 2011 | 12:26 AM
pewterliftedz's Avatar
have you talked to your tuner?
Old Oct 12, 2011 | 12:41 AM
gamble686's Avatar
Sounds like you have a shift command table off in your tune. You need to take to your tuner.
Old Oct 12, 2011 | 12:58 AM
GMCtrk's Avatar
check ETC rev limiter settings.
Old Oct 12, 2011 | 01:18 AM
TXjeepTJ's Avatar
****.. tuner is in san antonio, I'm 8 hours away. I sent them an email w/ video in it
could my rear tires being 1/2" taller do that? (I had a blow out a few days after I sent in my tune form.. so the info never got to them)
Old Oct 12, 2011 | 07:32 AM
nonnieselman's Avatar
Could be low on timing and rich up there. I ran into that when i was learning how to tune my truck.
Old Oct 12, 2011 | 02:42 PM
TXjeepTJ's Avatar
Tuner says PCM/tune wouldn't cause that, says that the converter also seems too loose
Old Oct 12, 2011 | 04:51 PM
04SilveradoMykk's Avatar
Tuning would cause that. You need to have your truck datalogged to see exactly what is happening in the PCM while the problem is happening. Sounds like a fueling problem but no way to tell without datalogging
Old Oct 12, 2011 | 07:10 PM
MikeGyver's Avatar
Originally Posted by TXjeepTJ
... Fuel pump is holding pressure ...
Does that mean that you have about 8 psi over your base pressure at the time this happens?
I say +8 psi assuming you are boost referenced. It sure seems like a fuel supply issue to me.
