electronic to cable TB conversion?
Old Sep 30, 2009 | 08:30 PM
2001CamaroGuy's Avatar
Default electronic to cable TB conversion?
What is required for the electronic to cable TB conversion?
Can the original PCM be "adjusted" to work with a cable TB or does it require a reflash to an "older" year with the cable?
If the PCM is reflashed to an "older" year, would this prevent passing an OBD2 emissions scan?
Old Sep 30, 2009 | 08:33 PM
BlackGMC's Avatar
Resident Retard
I dunno but why do you want to do it if you don't mind me asking?
Old Oct 1, 2009 | 01:16 AM
T56 swap planned and it is a known issue that the cruise control will not work in 6th gear with the electronic TBs. I have a possible solution but should it fail, I might need to convert over to the cable TB to regain cruise control.
turbo6c3
Oct 5, 2015 06:11 PM
Silver8ado
Sep 30, 2015 11:42 AM
99bluefirebird
Sep 17, 2015 08:05 PM
spooneralmighty
Sep 11, 2015 02:28 PM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
