ECM update
Old Mar 26, 2009 | 08:52 PM
saphunt2r's Avatar
Default ECM update
I have a 99 Silverado with a "05" 5.3 H.O; running on my stock 4.8 ecm..I also have a 2002 ECM #12200411 that came out of a truck with 8.1 in it, I would like to use this ecm on my truck if possible? And what would be the best why to do this? All input could help please.....need to start my tune with one of them , getting HP Tuners..
Old Mar 27, 2009 | 12:59 AM
Wheatley's Avatar
Truck Sponsor
Take the PCM ending in 0411,and flash a 02 5.3 file in there.You will need to do a write entire (not write calibration only) to do this.Anytime you flash a different OS in the PCM,you must do a write ENTIRE.
If you need a stock 02 5.3 file or any help,just send me a pm
Old Mar 27, 2009 | 01:19 AM
budhayes3's Avatar
PT's Slowest Truck
Just a note, the 99 truck came with 21 lb injectors, and 00 and up are 24.7, so you should either adjust the tune accordingly, or upgrade to some newer injectors BTW, installing an 02 PCM in my truck cured the false KR problems I was having after my cam swap with my original 99 PCM.
Old Mar 27, 2009 | 07:18 PM
saphunt2r's Avatar
P.M sent....I did use the 05 5.3 injectors just changed my fuel rails..
Old Mar 27, 2009 | 08:02 PM
Wilde Racing's Avatar
How do I change this text
I also like using the values used in the 05 tunes when the tables match up...
shootermwc
Oct 8, 2015 01:45 PM
Silver8ado
Sep 30, 2015 11:42 AM
dantheman1540
14
Sep 28, 2015 09:22 PM
lxcoupe
Sep 23, 2015 12:11 AM
jleews6
Sep 8, 2015 10:17 AM
