-   Tuning, Diagnostics, Electronics, and Wiring (https://www.performancetrucks.net/forums/tuning-diagnostics-electronics-wiring-161/)
-   -   Ecm help! (https://www.performancetrucks.net/forums/tuning-diagnostics-electronics-wiring-161/ecm-help-553659/)
Chuy-nator Sep 13, 2018 09:22 AM
Ecm help!
I have a 2000 silverado I did an Ls1 swap, got a 5.3 harness from a 2001 and used an ecm that my buddy had laying around with a mild tune but it’s file locked so I can’t re use it...the truck turned on and ran with this ecm..I went ahead and bought one from a 2001 silverado Hd wit a 6.0l got a mail order tune from Texas speed and performance and now that i hooked it up it doesn’t seem to wanna start..my question Is.. is there a difference in the pin out on the hd ECMs that I have to change? The new ecm from the HD truck is a 0411 type
1FastBrick Sep 13, 2018 01:21 PM
Nope, but it could be a theft lock issue. or they did not change the Vin number to match your truck in the ECU.
RedXray Sep 14, 2018 05:02 PM
Don't think the VIN number has to match the truck. My V6 swap Sierra has a Silverado V8 VIN number and works fine. Matter of fact my tuner "tricked" the ECM to display the V6 VIN. That was a nightmare as HPTuners saw a mismatch in the OS and VIN. Lost $200 in credits trying to get it to work. Finally had to send it back to the tuner to have the V6 VIN changed to a V8. Have TSP e-mail you the tune file and post it here. We can see if it's a VAT's issue or the wrong trans (80e) segment that might mess with the PRNDL switch.
Chuy-nator Sep 18, 2018 06:08 PM
He did call and ask me if I’m using the 4l80 instead of the 4l60 I said “ no I’m using the 60 i just got this ecm and it happen to belong to a silverado hd 6.0
