do I need to do a crank relearn?
Old Jan 20, 2011 | 05:33 PM
devink's Avatar
Default do I need to do a crank relearn?
I put the new PCM in last night, did the security relearn. Everything is great and I don't have any codes or lights to speak of.
Old Jan 20, 2011 | 06:06 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Then no, probably not. Do you have access to software?
Old Jan 20, 2011 | 07:56 PM
devink's Avatar
No, I don't. I don't want to pay someone to do the relearn if it isn't necessary. There's no lights or codes.
Old Jan 20, 2011 | 10:02 PM
hirdlej's Avatar
You should still do a relearn, yes.
Old Jan 20, 2011 | 10:19 PM
devink's Avatar
will I do any harm with light driving? I cant get this done until next week.
Old Jan 20, 2011 | 10:22 PM
trever1t's Avatar
no. If you have no code it isn't necessary. You can do it for S&G but when I had a mail order tune I never did one.
Old Jan 20, 2011 | 10:32 PM
06MonteSS's Avatar
FormerVendor
YES!! you need to get the crank relearn done! especially if it's not the original pcm from your truck originally... do it!
"A CASE relearn is an advanced way for the truck to detect misfires, based on the relationship of the cam position sensor to crankshaft position sensor. Anytime you permanently intend to install a PCM that did not come directly out of your truck, you need a CASE relearn."
Old Jan 21, 2011 | 09:20 AM
trever1t's Avatar
well then it appears I am misinformed. I will concede to the experts.
Old Jan 21, 2011 | 10:02 AM
hirdlej's Avatar
Whenever you replace a crank, cam, pcm, timing chain set, cam sensor, crank sensor, etc. YOU MUST DO A RELEARN. As I've stated in other post, I do this on high mileage trucks for people and often times will even see them run better since the injector firing, spark timing is more accurate.
Old Jan 21, 2011 | 11:51 AM
trever1t's Avatar
Sure, but in my experience it wasn't a "requirement" when swapping PCMs.
Easy enough to do if you have the right software.
