Demonic misfire gm 5.3
#21
the first shop found a bad injector after I had replaced all 8, but one showed up to my house already broken and they found another one gone bad on the truck itself so they charged me for that and fixing an issue I've been having on and off with tail lights not working. 2nd shop didn't charge me anything even when I offered to pay them a little just for the intake gasket. For shops I'm only down like $4-500 but with parts I'm down about 2x that at least
#22
Custm2500's Rude Friend
If they have changed all the parts that you stated above and you have the correct fuel pressure. I would suspect a mechanical issue.
Did they Physically have the heads off?
#23
I don't recall any good compression gauge ever saying "Normal" . Normal is not a specification... LOL
If a guide or something is bad when I pop the heads off then I'll get it fixed and re install the heads but with the help of a pro to make sure I'm torquing them down correctly.
#25
Problem is .. I adamantly take care of this truck. It's original paint, wheels, body, everything besides the headers and muffler. Bought it with 124k on it and barely any scratches or rust on it. I've taken the best car I could of this thing. Oil change every 3k, kept tranny and coolant topped up, checked oil every other week and it never burned hardly any. I'd put the 5.5qt in it every oil change, and when 3k was up I'd still have little over 5qt in the truck. Oil pressure has always been at 55-60psi at idle even when its hot.... unless somehow an air bubble got caught but I dont have any idea how that could happen. The issue started one day on my way to the tech college I attend, I came to a stop at a light and noticed the wobble. It's been parked for the last 75 out of 90 days at least
#27
Have you considered a leak down test? Sounds like those shops don't want to get to heavy into this truck or your truck is pushing their knowledge of auto mechanics. lol question. what heads are on your truck? If this was me, I would do a leak down test, that will help you if you have any mechanical damage, Id check the fuel rails for debris just for ***** an giggles. ( seen it before) After that id start looking at the harness. You can always do the good old Ford wire wiggle test while its running see if anything changes. If that don't do anything maybe start looking at getting a new harness or chasing wires down. By no means am I saying any of this is the issue, kinda just spit balling ideas off of what I read. Maybe see if you have any vaccum leaks. ALSO I would do your own compression test, I feel like they didn't really do one, they just told you that to get you gone. I have chased my tail before after someone said they "DID" something an they really didn't.
#28
#30
I cant remember the specific code off the top of my head, but they are specific to those cylinders. I have tested the plugs, wires, and coil packs and then the shops did as well. Randomized all injectors and ignition components multiple times and problem persisted on 5 and 6
