DBW to DBC ?
I looked into converting to DBC once, but never completed it. The IAC is different with different throttle bodies. I would just get a throttle body that already has one on it as they are fairly expemsive. Id there any particular reason you want to make the switch? I was having problems with a supercharger, but you should be fine with a turbo.
Exactly, this will tell you if its easy for you or not, and if you have the correct PCM which has a driver for the stepper motor in the IAC.
http://www.lt1swap.com/cable_conversion.htm <-- Pretty much covers/explains it all.
mitchellmade
Sep 27, 2015 08:27 PM
xtrooper89
Sep 21, 2015 06:03 AM
