Cold Weather Lean Code
Would cold weather case a lean code? I have a blackbear tune and when it got cold the codes were thrown.
Thank you |
Cold weather lean codes could mean that the intake gaskets are leaking.
is it running rough or anything?
Originally Posted by viciousknid
(Post 4600854)
If it idled rough when cold out and got a lean code that's normally a sign of an intake gasket leak as scooter said.
If it's running fine i'm not really sure unless it's just a really small leak. |
How cold are you talking about? It's -10F here today, no lean codes, and I'm running my speed density tune that I "tuned" last summer. So far it's been running just fine as low as -20F. I drive my truck every day that it doesn't have a broken transmission.
Originally Posted by AKlowriderZ71
(Post 4601008)
Just used my extreme example to show you that I don't believe the "cold weather" is the reason for the lean condition. It's likely lean for another reason, like intake gaskets, fuel delivery, or bad/dirty MAF if you're running one.
Post up what you find wrong with it. |
Try cleaning the MAF. the IAT sensor could be dirty
Hmmmm, i'm glad i read this. my truck throws a code too every time i let it idle too long. might have to check my intake gasket too.
| All times are GMT -5. The time now is 10:01 AM. |
