Cold start afr?
#23
Do you know if they dialed in the VE table. Because the EQ table reference the VE table for a base number.
Off subject, but why did you decide to run the maf vs. a 2 bar sd tune?
#26
Yes drivability with the MAF in most cases is better, steady state fueling is much improved with the MAF. Just because you are running forced induction does not mean that you "have" to automatically go with a 2 bar SD tune. I know their are a lot of guys in general and have tuned a lot of guys running a MAF with a blower or turbo and are making a lot of power.
If running the VE/MAF hybrid that the factory uses the VE table also needs to be tuned
especially with the mods you have done.
But as always first thing's first, make sure ALL of the injector data is correct in the tune before you even start tuning the VE and MAF otherwise those tables will end up being all jacked up pretty bad if they are tuned based on bad injector data.
#28
Yea on a daily driven truck, it would make more sense to me to use the MAF. Most of the forced induction guys on here and ls1 don't so just wondering what pushed him in that direction.
Klugg's: Did you look at his tune?
Mossyoakglock
Aug 28, 2015 12:49 PM
superchomper2003
Aug 26, 2015 09:39 AM
Mossyoakglock
Jul 17, 2015 08:30 AM
